[phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 486: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead
[phpBB Debug] PHP Warning: in file [ROOT]/includes/functions_content.php on line 678: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead
[phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 115: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead
[phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4799: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3851)
[phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4801: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3851)
[phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4802: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3851)
[phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4803: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3851)
 Hondaclub-belgium.be • Toon onderwerp - olie temps koude weer
Berichtdoor Dj3scoupe » zo 28 dec 2014, 19:45
laatste dagen met de kou gemerkt dat er toch serieus verschil op zit met de D-series.
ritje da ik vaak doe zit ie nu dik 15 graden lager. ter info, de plaat die er zit als je geen airco hebt heeft wel nut met de kou!
heb als test die er eens af genomen en duurt toch opmerkelijk langer eer de olie opwarmt.
nog mensen die dit merken? B en K series? of kunnen die er beter tegen
Mix sets@
my honda:
  • Re: olie temps koude weer
    Berichtdoor frederique_vl_ » zo 28 dec 2014, 20:22
    wat ook al wat helpt tegen de koud is een bodemplaat onder u motor dan blijft de warmte van u radiator ook zitten onder u motorkap vooraan
    olie duurt nu inderdaad langer voor op te warmen
    veel last heb er zelf niet zo van want in mijn karter ziet zo een olieschot gelast
    en dat plaatje helpt inderdaad in de winter maar bij mijn zijn die er uit omdat airco heb dus is heel mijne neus vol
    rode crx del sol VTI
    frederique_vl_
    Woonplaats: zottegem
    my honda:
    Berichtdoor HondaNickx » di 30 dec 2014, 13:12
    Oliesensor in de carterpan steken ;) .Achterin het blok op die oliesandwichplate loopt die altijd 10 graden warmer tov de temp in de pan ( door o.a omgevingstemp.)
    Mijne wordt altijd 80° met normaal rijden en nu met het koude weer duurt het wat langer ma wordt ook nog altijd 80°zonder afschermplaat van de AC.
    Voorheen op de sandwichplate was dat altijd 90°.
    HondaNickx
    my honda:
    Berichtdoor WhiteSol » di 30 dec 2014, 13:17
    my honda:
    Berichtdoor kristo » wo 31 dec 2014, 09:52
    my honda:
    Berichtdoor HondaNickx » wo 31 dec 2014, 13:15
    Ac condensor is allang niet meer daar en rij al heel lang met een gat daar ja.Bij mij hangt men nummerplaat daar ook nog voor dus dat houdt ook al wat tegen.
    De plaat zelf heb ik ooit al eens overgetekend in een aluminium plaat van 2mm of 3mm dik.
    Met de plaat zal je minder drag hebben en de warmte van de header zal meer onder de kap blijven.Zonder plaat blijft het wat frisser ten nadele van de header dan.
    Als je langs voor kijkt door de bumper dan zie je waar de lucht direct tegen blaast en dat is voornamelijk header,motorblok en oliepan.
    Ik ben niet meer zeker maar ik dacht dat met die plaat erop dat men olietemp iets hoger werd en toen had ik mijn olietemp sensor nog vanachter op de sandwichplate zitten.
    Vandaar dat ik ze eraf gelaten heb.Hangt ook weer af wat voor soort header je hebt.(Gecoat of niet enz)
    Dit was op een civic EK met Pre facelift bumper.Op een andere bumper kan dat meer of minder lucht zijn.
    Beste is eens ne keer testen ;) het heeft voor en nadelen.
    HondaNickx
    my honda:
    Keer terug naar Algemeen
